TwinTurbo.NET: Nissan 300ZX forum - If they are on the exterior they shoud be visable>>>
Subject If they are on the exterior they shoud be visable>>>
Posted by ZUL8TR on March 07, 2011 at 7:18 AM
  This message has been viewed 107 times.
In Reply To finding Oil leak! posted by Yuengling on March 06, 2011 at 07:06 PM
Message as to there probable location. Pressurizing will not reveal leaks at the valve covers since the oil is no longer pressurized once it leaves the valve train onto the cam lobes. All you can do there is regasket the covers.
Pressurizing will reveal leaks at the oil filter, oil pressure sending unit, front and rear crank seals and a few other locations and 5psi is reasonable for searching since oil pressure is 20 to 80 psi.
ZUL8TR in Orlando,FL
